jamieallan
Nov 23, 2021Tutor
Netgear EX6150 AC1200 Device Connection Problems
Hi, I've used my Netgear EX6150 for a number of years as an Access Point wired directly to my router. My router is a Sagemcom Plusnet Hub One. All worked fine up until I had to move the router and 6...
jamieallan
Nov 23, 2021Tutor
Thanks for the reply. I did originally set up the 6150 using WPS but this morning reset it and used a fixed IP and set the router/extender path to 2.4G only - although only about 5 metres apart I've 3 walls and doorways between the devices as the 6150 is in an extension to the house. I haven't changed anything else - should I? I'm now seeing a significant improvement in speed on wifi. I also managed to fix my Canon printer problem by connecting to it by usb and then manually changing the printer port with a fixed IP address.
Nov 23, 2021Guru - Experienced User
fastlane (using 1 radio dedicated to just router---extender communition) can sometimes help speeds and sometimes hurt them.
Reason for this is the 2.4ghz band isn't nearly as fast as the 5ghz band. So if you're using it for backhaul and there's interference, it can be the bottleneck. If its increasing your speed, awesome! Keep using it.
If you notice a slowdown, you can always swap them and see if the 5ghz works better as backhaul.
