Lakevilledon
Jan 23, 2021Follower
Netgear EX6150 Multiple devices on a single network?
I have the Netgear EX6150 Extender and am wondering can I put multipal extenders on the same WiFi Network? THX
Jan 23, 2021Guru - Experienced User
Yes. you can.
But I'd highly recommend against daisy chaining or you'll get significant throughput drops.
Daisy: Router------>extender------>extender
Star: Extender<---------router-------->extender
I'd also caution that if you're using a mesh extender and the extenders are to close, they can sometimes end up attaching to each other and not back to the router.
