tommyj23's avatar
tommyj23
Follower
Mar 19, 2019
Netgear ex6200 extender very slow
I have a verizon router for my main wifi. When standing in my family room on one side of the house i get speeds of 88.0 mbps download.. the wifi is very fast and i have no problems.
my house is very long. So i bought the netgear ex6200 wifi range extender because it had good reviews.  When in the room with the wifi extender, im only able to get a speed of 12.1 mbps download. My bedroom is the very next room over from the room with the extender and we have had issues at night time with the wifi.  I found it odd that even while standing in the room with the extender i still got such slow speeds.  Am i doing something wrong?
1 Reply
  • plemans's avatar
    There could be several things causing problems. You need to narrow it down to where the slow down is coming from and if its a user error or a hardware problem.
    the EX6200 lets you select which band you connect to and if you want to use fastlane technology or not. If it was me, this is how i'd trouble shoot.
    1. Hardwire into the extender. Speed test from there. If you're speeds are slow even hardwired in, its something in the backhaul. That could be: A. to far from router, if you're extender is to far from the router you're not going to have much speed. better to be a bit closer and have high throughput than to far and have slow speeds. B. using 2.4ghz to extend the network (lower bandwidth) C. wrong channel. you could be getting interference from other wireless channels.
    2. check your fastlane setup to make sure you have for your specific situation. With one setting it gives high throughput at the cost of sacrificing a band, the other will cut your bandwidth in half but still allow you both bands. Play with these settings to optimize how you'd like it.  read more here
    https://kb.netgear.com/24662/What-is-FastLane-Technology-and-how-do-I-configure-it
    try playing with these and let us know how it goes.
