AcePilot2002
Apr 17, 2022Tutor
Netgear EX6400v2 power light stays amber and won't connect
My EX6400v2 extender was paired with / connected to an ARRIS DG3450 cable modem/router installed by my local cable tv/ISP provider. It would occasionally have intermittent network connection drops bu...
AcePilot2002
Apr 17, 2022Tutor
Unfortunately when I attempt to follow the command prompt option for uploading the firmware from my computer, the response I get after hitting enter on the tftp command is the following:
Connect request failed
When I tried using the tftp windows client option following the instructions from this website:
it again appears to just 'hang' after I hit the 'put' command, even though I leave it alone for nearly 10 minutes. Instead the power light continues to remain a solid amber/orange color.
Is the extender device irretrievably 'bricked' / wrecked? Any other thoughts/suggestions would be deeply appreciated.
Apr 18, 2022Guru - Experienced User
tftp and nmrpflash are sensitive to timings. (try them both).
Its taken several times before with a couple I had to get them to go through.
don't give up after one attempt
