Tanuki2000
Apr 30, 2021Aspirant
Netgear EX700: can’t see NETGEAR_EXT
I am trying to set up the EX7700 as an access point. I have already set it up successfully as a range extender connected to the router via Wifi, and I am now trying to connect it using Ethernet c...
May 01, 2021Guru - Experienced User
If you log into the router and find the extenders IP address, you can log into and see what you have the ssid set as.
- Tanuki2000May 01, 2021Aspirant
Thanks, but I can't see the extender in the list of devices.
- Tanuki2000May 02, 2021Aspirant
FYI I was able to connect to the NETGEAR_EXT after resetting the extender via the reset button (paperclip).
Eventually got to talk the tech support after getting booted off three times and being on hold for a couple of hours.
Extender works great as an access point, covering this huge backyard and servicing the granny flat.
