vplondon
Nov 09, 2021Initiate
NETGEAR EX7000-100UKS Wi-Fi Mesh Range Extender EX7000
Four years ago I have pruchased EX7000 extender , which works fine. However due to configuration of my house it not cover the entitre house (non Netgear router is on the second floor, while extender ...
Nov 09, 2021Guru - Experienced User
running 2x mesh extenders can sometimes work great. And other times be a massive headache as they end up connecting to each other instead of the router.
Its why I usually recommend switching to a full mesh system like the Orbi or MK nighthawk for those needing more than 1 extender.
Not saying you have to. You can pick up a matching EX7000 and use it. If it does create issues, simply change one of the extenders or the router's ssid to something different so the extenders aren't connecting to each other.
vplondon
thanks very much
plemans wrote:running 2x mesh extenders can sometimes work great. And other times be a massive headache as they end up connecting to each other instead of the router.
