mediatrek
May 20, 2016Virtuoso
Netgear EX7300 Feature & Spec Questions
 I have a few questions about the Netgear EX7300 before putting down the money to purchase it that I cannot find answers to in marketing materials or support materials for the product:       In access...
- May 25, 2016
mediatrek
1. In access point mode, does it support band steering?
[Ans] No.
2. Is transmit beam forming (TXBF) enabled on the 2.4GHz radio?
[Ans] No. Only for 5GHz.
3. Can MU-MIMO be enabled/disabled by the user for the 5GHz radio?
[Ans] MU-MIMO is enabled by default for 5 GHz with no GUI option to enable/disable the feature.
4. Does the EX7300 use the same older (circa 2012) QCA9558 802.11n SoC solution that the Netgear EX6400 has? If not, what does the EX7300 have for its SoC?
[Ans] Yes, both use the same solutionHope this answers your questions
DarrenM
DarrenM
May 25, 2016Sr. NETGEAR Moderator
mediatrek
[Ans] No.
DarrenM
