MichealRT's avatar
MichealRT
Initiate
Jan 28, 2022
Netgear EX7300 Questions
I have a couple of questions regarding the EX7300(v2).
1. Does this extender support all routers/modems that aren't NetGear's and would they work as intended? Or is this only compatible with NetGear routers?
2. Does it support Zero Wait DFS? Currently struggeling with my current extender because it doesn't support that. I'm looking to replace my RE650 from TP-Link because I have had so many issues with it.
Thanks!
- MichealRT
  • plemans's avatar
    Jan 28, 2022
    i couldn't say if it has zero wait built in.
    I don know the RE650 is a pretty solid extender.
    so I can't say if the EX7300 would function any better than the RE650.
    I'd try switching off the dfs channels. If you're in an area with frequent DFS usage, it might not be a reasonable option to use.
    The good think is the 5ghz doesn't broadcast as far or through as much materials so even in apartment/condo living, its still pretty efficient and usable.
  • plemans's avatar
    1. Does this extender support all routers/modems that aren't NetGear's and would they work as intended?----For the most part yes. Some mesh routers it most extenders have issues with. Like the G3100 from verizon. Its been locked to its own extenders. So its not a all or nothing thing.  Or is this only compatible with NetGear routers?----for the most part, it works with most all routers. Its just the mesh ones and poorly coded ones that cause issues.
    2. Does it support Zero Wait DFS? Currently struggeling with my current extender because it doesn't support that. I'm looking to replace my RE650 from TP-Link because I have had so many issues with it. ----Zero wait dfs is part of how DFS devices are supposed to function. If a devices supports dfs, it should work fine on DFS. But if you're in an area with frequent broadcasts on dfs, it might not be a good frequency to use.
    Thanks!
    - MichealRT
    • MichealRT's avatar
      MichealRT
      Initiate
      Thanks!
      - MichealRT
      I have contacted TP-Link support regarding the support of Zero Wait DFS on the RE650 extender. They said that it doesn't support Zero Wait DFS but it does support DFS? So, is the EX7300 a good option or should I look into something else? My RE650 does work with the modem from my provider.
      • plemans's avatar
