MEDMAD
Dec 09, 2023Aspirant
Netgear EX7500 5G channel selection
I have a Netgear EX7500 wifi extender, connected and configured on 2.5 ghz and 5G. Is there a way to choose a channel other than the 4 default channels, 36, 40,44 & 48? The online documentaion sugg...
- Dec 11, 2023
There isn't and here's way.
The EX7500 being a triband device, uses the connection back to the router as the "dedicated" backhaul. That's all it uses that channel for to preserve throughput. If you changed it so both 5ghz channels could use that same channel, only one could broadcast at a time (or it'd create interference). And that'd slow it down big time.
So whatever you set your router as for 5ghz channels, the extender will use for the backhaul. If you changed the router's broadcast to the lower 5ghz channels, then the extender could use the higher channels for broadcast
Dec 11, 2023Guru - Experienced User
