RobLuben
Jan 09, 2022Tutor
Netgear EX7500 Bouton alimentation clignotant
Bonjour, Mon répéteur Netgear EX7500 reste bloqué avec le bouton d'alimentation, en bleu, en position clignotant. Que faire pour débloquer la situation ? Merci d'avance pour votre aide :s...
Jan 09, 2022Guru - Experienced User
Have you tried a factory reset?
Push and hold reset for 7-15 seconds while its powered on.
if that doesn't help, you can try recoving it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
- RobLubenJan 09, 2022Tutor
Factory reset doesn't word.
Thxs for the link, but Netgear EX7500is not a router.
