Davo36
Dec 15, 2022Guide
Netgear EX7500 not booting up.
My extender was working fine yesterday. I moved it to a socket in another part of the house, and now it's just sitting there booting forever. By that I mean a slow pulsing blue power light. ...
Davo36
Dec 16, 2022Guide
Ok, I had a go at this.
This is what it said prior to the update: Firmware Version: V1.0.0.28_1.0.43
I updated to: Firmware Version 1.0.1.76
I did it manually but downloading the file and installing it.
And then I got the dreaded blue pulsing light again...
I'll keep going...
Dec 17, 2022Guru - Experienced User
Try downgrading a version. Maybe the one you're on has issues that you're discovering
- Davo36Dec 17, 2022Guide
It's a brick now. Can't do anything with it at all.
Slow blinking blue light. Reset button does nothing. Power/WPS button does nothing.
- plemansDec 19, 2022Guru - Experienced User
You can try recovering it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash - Davo36Dec 20, 2022Guide
Thanks I'll look into this.
Oh, the extender I have doesn't have an ethernet plug on it. So no way to connect it to a pc...
