Davo36
Dec 15, 2022Guide
Netgear EX7500 not booting up.
My extender was working fine yesterday. I moved it to a socket in another part of the house, and now it's just sitting there booting forever. By that I mean a slow pulsing blue power light. ...
Dec 19, 2022Guru - Experienced User
You can try recovering it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
Davo36
Dec 20, 2022Guide
Oh, the extender I have doesn't have an ethernet plug on it. So no way to connect it to a pc...
