Davo36
Dec 15, 2022Guide
Netgear EX7500 not booting up.
My extender was working fine yesterday. I moved it to a socket in another part of the house, and now it's just sitting there booting forever. By that I mean a slow pulsing blue power light. ...
Dec 27, 2022Guru - Experienced User
If you've got it back to blinking, maybe you can access it and try downgrading the firmware?
Is it still within warranty?
Davo36
Dec 27, 2022Guide
I don't see how I can access it to change the firmware?
No it's not under warranty any more.
- plemansDec 28, 2022Guru - Experienced User
Can you wirelessly connect to it at all and log into it?
- Davo36Dec 28, 2022Guide
No I assume not since it's not booting up. It just has that blue blinking light again. Permanently.
- plemansDec 29, 2022Guru - Experienced User
Sounds like a hardware failure. And if it doesn't have an Ethernet port, its rough to flash it. Sorry
- Davo36Dec 29, 2022Guide
Yeah thanks very much for your help.
