misanil
Sep 01, 2022Aspirant
netgear EX7700 - how to disable the Mesh function (same network name of router)
dear all, I have some problems with the Mesh function of my EX7700; it works perfectly with different devices but it seems that is causing problems to mi WiFi Security Cameras. Is there a procedure ...
misanil
thank you for your immediate response.
I'm going to try this solution and I'll let you know results
regards
Lorenzo
misanil
Just a question... can I re-run setup using Nighthawk APP via smartphone, and how?
Otherwise, please can you kindly direct me towards the right procedure?
thank you again
- plemansSep 01, 2022Guru - Experienced User
I would just factory reset it and rerun it with the installation assistant. Its during setup with the assistant that you uncheck the box.
here's a video of using the assistant.
https://www.youtube.com/watch?v=yJVklshxBMk
