philwangsd
Jan 04, 2021Follower
Netgear EX8000 much slower after upgrade to Netgear RAX70 Wifi 6 router
Both router and extender are up-to date firmware. 1 GIG download internet service from Xfinity. EAX8000 previously pairs with R7800 received around 366 mbps (290-400 range) with wifi 6 adaptor/r...
Jan 04, 2021Guru - Experienced User
The EX8000 has 2x 5ghz bands. 1 works in the lower band and 1 in the higher. 1 of them has the 1733mbps option (4x4 antenna) and the other is 866mbps (2x2 antenna).
so depending on which one you're using as backhaul. will impact your front haul speeds.
I can't remember which one is which in terms of useage.
Try swapping which channels you use for the RAX to the lower 5ghz then reset the extender and see if its connecting at the higher or lower speeds. If its lower, then change the rax to the higher and reset the extender. (not reboot, actually factory reset the extender).
in terms of the RAX, it uses 160hz wide channels in the DFS range to hit the 4800mbps. If you're near an airport or anywhere with DFS usage, you might not get the usage of dfs.
Nighthawk RAX70 | WiFi 6 Router | NETGEAR Support
