mbguercio
Dec 26, 2019Aspirant
Netgear EX8000 Nighthawk X6S Tri-Band Mesh Extender - ISSUE
Ever since I updated the Firmware on my Netgear EX8000 Nighthawk X6S Tri-Band Mesh Extender to V1.0.1.206 it drops the signal after a few days and I need to reset the whole range extender and set up ...
mbguercio
The extender factory resets and I have to reinstall every time is crashes after a few days.
1. My modem is: Arris Surfboard SB6190
2. Firmware on my router is: V1.0.2.130
3. I have not tried changing the channel yet, but will try that. There has never been an issue before this firmware update though.
I need the extender for pushing the signal into my backyard. The house is covered fine by the router, but for teh signal to reach into the backyard I need the extender.
Dec 26, 2019Guru - Experienced User
You could try downgrading the firmware on the extender. You could also try reinstalling the firmware. When it resets itself, its not reloading firmware so if it was corrupt somehow, the reset doesn't fix the issues.
