ARH47
Nov 08, 2019Tutor
NETGEAR EX8000 white lights blinking, will not factory reset
White lights on front of EX8000 extender are blinking. Extender will not start up. All I did was turn off the extender, which was working fine, then turned it back on, now all it does is blink whi...
Christian_R
Nov 15, 2019NETGEAR Employee Retired
ARH47,
You may have to reflash the firmware again here is a guide how to do it using TFTP.
https://kb.netgear.com/22688/How-to-upload-firmware-to-a-NETGEAR-router-using-TFTP
Christian
- Tofu101Nov 21, 2019Star
The link doesn't work.. I'm having the same issue and about to take my Ex8000 out to the garage and shoot it.
- ARH47Nov 21, 2019Tutor
I haven't had time to attempt the reset yet, but here is some other info I found:
Someone else with the same problem:
Here is the link to uploading the firmware that was in that post:
https://kb.netgear.com/000059633/How-to-upload-firmware-to-a-NETGEAR-router-using-TFTP-client
