Flyersgolf
Aug 06, 2020Aspirant
Netgear EX8000 X6S & Sonos Amp
The Sonos amp located in a screened in gazebo, powers pool speakers. The Netgear EX8000 X6S wifi extender is in the main house. The initial install worked fine for two months. Now there are serious...
Flyersgolf
Comsat xFi gateway, netgear has latest upgrades within the week.
Aug 06, 2020Guru - Experienced User
Flyersgolf wrote:
Comsat xFi gateway---which one? they make more than 1.
, netgear has latest upgrades within the week.----firmware numbers help. especially in case others have the issues, a firmware team monitors, or if its not the latest. Its why we ask.
a couple things you can try.
1. set a static ip address for the extender in the comcast box. in case its a comcast issue.
2. downgrade the firmware. maybe the extenders firmware is the issue
3. is the sonos box hardwired in or wireless? if wireless, try changing the wifi band and/or channel used.
4. check the sonos site. maybe a firmware update from sonos caused the issue.
