FrankHD
Oct 23, 2022Initiate
NETGEAR_EXT does not show up and WPS button does nothing
Just purchased a 4-Stream Wi-Fi mesh extender EAX15-100NAS (a small white unit about 2.5x3x6). Plugged it in and after a boot up period the power light turns green. I have tried looking many times for NETGEAR_EXT and it does not appear in my list. Nighthawk says I am not connected to a router. My router is from Time Warner / Charter and is a Sagemcom Fast 5260. I am not sure of my router uses WPA, but I suspect it does. I tried pushing the WPS button on the Netgear extender and I held it for two minutes. The WPS light never started flashing. I tried resetting the Netgear device and the power light began to flash, but once the power light turned green I was no better off than before. Any help would be appreciated.
Factory reset the extender. Push and hold reset for 7-15 seconds while powered on.
Then try using the installation assistant
Here's a video of how to use the assistant.
https://www.youtube.com/watch?v=yJVklshxBMkYou can also try hardwiring a pc/laptop into the extender and setting it up that route.
- Thank you for the advice. I did try resetting the extender, also to avail. Next step will be to try hooking up a laptop. The whole time I am thinking it should not be this hard…
It shouldn't but the fast devices aren't the best. And they like to push users to their own extenders. You can google it.
