Graham571's avatar
Graham571
Follower
Sep 04, 2019
Netgear extender AC750 Model EX6000 unable to accept wifi password when connecting to extender
Hi all,
Hoping someone can advise what to do here. I have a Netgear AC750 Model EX6000 wifi range extender. I believe I have initially set up the extender correctly as the power / Router & wps/mode LEDs are solid green lights.
However, when I try to connect an Android phone (Galaxy s8+) when I enter the wifi router code (using the <router address>_2GEXT (_5GEXT) it is saying that I have entered the incorrect password, when in actual fact it is the correct code for the router as the pc is also connected on the same passcode. Please advise what I can do or if the extender is compatible or not with what I'm trying to use it for.
Any help gratefully accepted.
Thanks
Graham571
1 Reply
  • Christian_R's avatar
    Christian_R
    NETGEAR Employee Retired
    Graham571,
    Factory reset the extender by pressing on the small black button using a pin for 15+ seconds then join the NETGEAR_EXT wifi network using a phone or laptop. After you connect to the NETGEAR_EXT network with your phone or laptop, browse to www.mywifiext.net and follow the setup instructions.
    ~Christian
