Retired_Member
Feb 02, 2022Netgear extender EX6100
I have been using my extender for a number of years but it only works with 2g. I cannot get it to work with 5g. Anyone who can help would be appreciated.
Feb 02, 2022Guru - Experienced User
what router are you connected to?
What firmware is on it?
What method of setup did you use? (wps or the installation wizard)
what error/issue happens when you try to setup the 5ghz?
