retddon
May 30, 2022Initiate
netgear extender ex6120
I have a NETGEAR EX6120 extender connected to my Verizon 5g router. I can connect all devices thru the extender to the internet with no issues (including 2 iPads) except my iPhone 13 and iPhone 12....
- May 31, 2022
are you using icloud relay or private mac/ip address on them?
Try it with those disabled.
did you setup the extender using wps or using the installation assistant?
What verizon router is it?
May 31, 2022Guru - Experienced User
retddon
May 31, 2022Initiate
Thank you for the information. I turned off the private wi-fi address setting for only the Wi-Fi extender and now it works perfectly.
Thanks again for the assistance. Just a note that on my ipads that setting is turned on and the extender works.
Don
