eagletracker1
Aug 31, 2023Follower
Netgear extender EX7000 no internet access
I had a power outage last night and when I woke up the extender had actually factory reset itself somehow. I tried to reset up using the WPS buttons. It said the access points were set up but the s...
zebraxoxo
Sep 07, 2023Aspirant
You can try accessing your extender through its IP address rather than the mywifiext site. The Netgear getting started guide suggests <a href="http://192.168.1.3" target="_blank">http://192.168.1.3</a> for the ex7000 but that might not be it. To find your extender's IP address you can logon to your router and look for it in the connected device list. Also sometimes <a href="http://mywifiext.local" target="_blank">http://mywifiext.local</a> works.
