mihailosundic
Feb 19, 2020Aspirant
NetGear Extender EX7000 very slow download speed 40x slowdown
Hello, I would like to ask if anyone had an issue with extender and if you know how to fix it. I have a speed issue with my EX7000 range extender. Main router has speeds D/L = 52 Mbit DL and 8.38...
- Feb 20, 2020
I actually had bought it with older firmware and when it was not performing well I updated it to the latest, I don't think that two firmwares are bad for the device, than it's negligence and mostly anyone would complain for EX7000 to be not operational.
Actually I managed to get it working, in a way... but only on one channel, I actually put it in fast lane but the opposite of what I've been doing, it works in 5 Ghz mode from Main Router to EX, and in 2.4 Ghz from EX to other devices.
It isn't quite what I wanted because I wanted 2.4 between my MR and EX where I would have 3 walls and 30ft between, and
5 Ghz between EX and clients since these are in the same room and room next to it (1 wall). I guess I'll have to settle with this setup.Now it shows speeds of 16 Mbps DL (out of 52 Mbps on my MR) and 8 Mbps upload (same as MR speed). It's still in the same
room as the MR, so I guess a little slowdown when I move it to the other room, but I guess it's much better than 1.7 Mbps.
Still not quite what I expected but let's say it is usable now, not really in value of 130$ IMHO, but what can I do now,
I don't really see how to make it work right at the moment.
Maybe someone would find this helpful too, it's a lot of trial and error, I'm not here to spit on the product, I bought it because
I think it's the best in class but some pieces seem to have bugs or compatibility issues in work with non NetGeat routers.
Will come back to leave my thoughts after I use it for a few weeks to see how consistent it is.
Thanks,
Mihailo
Feb 19, 2020Guru - Experienced User
Here's the steps I'd take.
1. Factory reset and re-install using the smart connection wizard.
2. Try re-installing the firmware. Potentially the firmware could have been corrupt. A reset only removes settings, a re-install overwrites the firmware. So re-install it, factory reset it, and re-install it.
You also can potentially downgrade the firmware a version. Maybe your device has a bug with your firmware.
I'd also move it a little further away. in the same room but 6-10ft away.
