burgirhig
Feb 04, 2020Aspirant
Netgear extender needing new password every day
Hi everyone, Im having massive dramas with my netgear wifi extender all of a sudden. It was working fine and now every day it tells me the password is wrong and i have to go online and reset it b...
Feb 04, 2020Guru - Experienced User
What firmware are you on?
What router are you connecting to?
have you tried re-installing the firmware? it wouldn't be the first time something was corrupted. Factory resetting only erases the settings but it doesn't re-install the firmware.
another thing you can check, is if there's another wireless extender broadcasting the same. I ran into an issue where someone was connecting to their neighbors extender and making changes.
- burgirhigFeb 04, 2020AspirantSorry - really non techie here, is firmware my computers protection software? If yes i have McAfee but not sure I under how that would affect the phones connected to the extender?
The router is the standard IInet one and it’s actually plugged into to it (Ethernet cable) as the signal really doesn’t reach anywhere we can plug the extender in. Also the computer has its own Ethernet cable so though I can unplug it and connect it to the wireless I always get good signal because I have to wfh and find wireless a little inconsistent.
On the internet - it shows up as my internet name with -ext on the end and all my neighbours are on Telstra so not even remotely close in name so I don’t think I could be mixing it up.
Thanks- plemansFeb 04, 2020Guru - Experienced User
Firmware is the coding that runs the extender. If you log into the extender, it'll list the firmware on its status page.
What model router is it? an actual model number.
Are you saying that you've ran a ethernet cord to the extender from your router? I'm just a bit confused by this.
- plemansFeb 04, 2020Guru - Experienced UserBTW
this is your support site with manual, firmware, install guides, and install videos
https://www.netgear.com/support/product/WN3000RPv3.aspx
