yuujh
Jan 17, 2025Aspirant
NETGEAR Extender Router EX3700
I have been using intermittently for several years. I've consistently encountered difficulties accessing the extender's menu via the router address or IP address. I would like to check for firmware u...
Jan 17, 2025Guru - Experienced User
what router are you connecting it to?
what method of setup are you using? If its wps, factory reset and install using the assistant.
Here's a video of how to use the assistant.
https://www.youtube.com/watch?v=yJVklshxBMk
what actual error do you get when you try to access it
