neege
Jan 14, 2019Follower
NETGEAR Extender will not connect to router
Hello community. I have spent the last three or four hours trying to sort out what is probably a very simple issue and I am no closer to a solution.
Basically, my NETGEAR EX2700 range extender stopped working and will no longer connect to my router. I have reset it (the extender) a number of times and followed all of the original set-up procedures, but the WPS green only flashes and does not remain constant. Currently located about two feet from router, but makes no difference.
Further to this, I am unable to access the mywifiext.net site.
I work freelance from home and depend completely on being online. Any help with this would be massively appreciated!
Many Thanks.
Many Thanks.
1 Reply
- Christian_RNETGEAR Employee Retired
Hello neege,
After resetting the extender, are you able to locate the wifi network "NETGEAR_EXT"?
~Christian
