EamonnSligo
Apr 10, 2020Tutor
Netgear Extender WN3000RP - problem trying to change it to new broadband router
I got a new broadband router, so wanted to link my Netgear Range Extender to it. At this stage, I have tried so many things, not sure where I am at. I have plugged the extender in, in the roo...
- Apr 10, 2020
try this.
1. Factory reset the extender. Push and hold reset while plugged in for 7-15 seconds or until the lights change.
2. hardwire a pc into the extender.
3. then try the setup wizard from the manual
Apr 10, 2020Guru - Experienced User
try this.
EamonnSligo
Apr 10, 2020Tutor
Thank you
plemans wrote:
plemans wrote:try this.
https://www.netgear.com/support/product/WN3000RP.aspx
try this.
