Bluesapphire
Oct 08, 2016Aspirant
Netgear extender WN3000RP
Hi....I am trying to update the firmware for the above extender. I have downloaded the file and it is a winzip file which is saying I need to purchase their product to open the file. The trial pe...
TheEther
Oct 08, 2016Guru
WinZip is a commercial program. You don't really need it. Windows should be able to natively unzip files, so uninstall WinZip.
Then download the firmware once more. It will probably be saved to the Downloads folder. Open the folder, right-click the file and select Extract All.
Bluesapphire
Oct 09, 2016Aspirant
Thank you Ether.....I managed to find the solution on a utube demo. It effectively follows your instructions. I opened the file which was in the downloads folder by right clicking and on it using windows explorer to open it. I then copied the file ending in .chk which was the larger file, into netgear site, which uploaded it into the extender.
I have explained this in detail as there maybe others who are interested in doing the same. It would be good for netgear to inform their customers about this as it avoids the cost of purchasing winzip.
