ReoX's avatar
ReoX
Follower
Feb 10, 2013
netgear extender WN3000RP
i hvae a problem with my extender i have a network printer attacehed to my wireless router when im locked on to the extender i cant print is there anyway i can make my extender extend my exsisting network without creating a new network ?? or do i need to get some other equipment for that ??
  • Retired_Member's avatar
    Retired_Member
    If your printer is properly and wirelessly connected to your main network, then you should be able to access it from the extender without difficulty unless you selected to "isolate" the extender network. Try rebooting both the printer and your main router and see if that fixes it.
  • when connected to a new network make sure you select private network and you enable printer sharing in your network.
    This al is selectable in your network options.
    You might also want to enable network discovery then your printer will be visible when turned on.
    This is a upnp function.
