refindmaxx
Jan 31, 2018Aspirant
Netgear Extender won't boot
I've had my exender packed away for a few years and needed to start using it again. When I plug it in to try and follow the installation instructions the unit won't boot. The power light stays ambe...
refindmaxx
Feb 02, 2018Aspirant
Hi Darren,
So I held it for about a full minute and nothing happened. It still has the solid amber light and won't boot. Is there anything else I can try?
DarrenM
Feb 06, 2018Sr. NETGEAR Moderator
You may need to contact support at this point if you are still under warranty.
http://www.netgear.com/support/contact.aspx
DarrenM
