ecrivellin
Dec 02, 2019Initiate
Netgear extenders
I bought 2 wifi netgear extenders ( WN 1000 RP and EX 6110) and I need to connect directly them to enlarge the wifi wave radius The aim is to reach a far corner of my house at larger distance of th...
Dec 02, 2019Guru - Experienced User
1. What router are you using?
2. Whats your plan for setup?
Star: WN1000RP<-------Router----->EX6110
Daisy chain: router------>EX6110 ---->WN1000RP (if you're using daisy chain, go this route as the WN1000rp is a single band device.)
With these types of extenders, I always recommend making sure they have their own individual ssid's (wireless names). This prevents them from trying to connect to each other versus the router. Or if you run in daisy chain, it prevents them from connecting to the router when you're wanting the other device.
Another option you can look into is fastlane. You could set the EX6110 in fastlane and use the 5ghz radio exlusive for connecting back to the router.
