ecrivellin
Dec 02, 2019Initiate
Netgear extenders
I bought 2 wifi netgear extenders ( WN 1000 RP and EX 6110) and I need to connect directly them to enlarge the wifi wave radius The aim is to reach a far corner of my house at larger distance of th...
Dec 02, 2019Guru - Experienced User
Please post about this in the wifi extender forum:
https://community.netgear.com/t5/WiFi-Range-Extenders-Nighthawk/bd-p/home-wifi-range-extenders
Thank you.
ecrivellin wrote:I bought 2 wifi netgear extenders ( WN 1000 RP and EX 6110) and I need to connect directly them to enlarge the wifi wave radius
The aim is to reach a far corner of my house at larger distance of the maximum radius of only one of the two extenders
Is there any operation to apply in order to reach the goal ?
Retired_Member
Dec 02, 2019
FURRYe38 wrote:Please post about this in the wifi extender forum:
Why??
There's lots of discussion here with how the Orbi works or does not work with extenders.
- ecrivellinDec 03, 2019Initiate
Thanks a lot for the prompt and exhaustive answers
Your support has allowed me to solve the issue
