AuntMimi
Sep 01, 2016Aspirant
NetGear Genie WiFi Range Extender Model #EX6100
I upgraded our modem from Comcast, our ISP. Do I need to do anything to my NetGear Genie WiFi Range Extender Model EX6100 or will it be a seamless transition because I am still using the same ISP an...
jguerdat
Sep 02, 2016Guru
Wrong forum.
If you have the same SSID and passphrase on the new router, you may be fine. I'd consider resetting the extender and set it up fresh again, just to be sure.
