Korben77
Sep 13, 2022Aspirant
Netgear Mesh AX1600 EAX12 loses wifi connection
Hello, I'm using a EAX12 as a AP in a bedroom and it is plugged into a RAX75 router. I have a laptop, tv, and Oculus Quest hooked up to it. Everything seems to work fine but than on the pc I get a...
- Sep 13, 2022
Negative I have removed VPN from both TV and PC once I started to have the issue. You are correct that that would be the common fact between the two. Also VPN is running on a TV and multiple PC's that are connected to the router WIFI but not the two connected to the AP as of now. Sorry this is very flustering. I have been dealing with this for some time now and have had many people try to help with no answer.
Sep 13, 2022Guru - Experienced User
I also realize nothing is running the vpn. But you have it installed (evidently from your post) on 2 devices.
And those 2 devices are the ones you're reporting issues with. Coincidence?
Korben77
