KevinE_111
Mar 01, 2023Tutor
Netgear Mesh Extender advice
I tried to hook up model 6150 tonight and couldn't. I had the nighthawk app downloaded. The chat discussion turned me to a phone call by another party. That party looked at my service as I let him hop on to my system through realvnc. He said my speed was fine, that I had way too many things running on my single IP address? That the DCHP needed reconfigured? Thay they could perform this service for a fee. Is this normal? I did not give out any financial info. Just wondering if this is normal? Thanks in advance
total scam. You must have googled a number and gotten a scam site. It happens a lot.
They're trying to sell you stuff you don't need.
What actual issue are you having?
here's manuals, guides, firmware:
https://www.netgear.com/support/product/EX6150.aspx
My wi-fi would not find "netgear" as a connection. The tech said I had too many items hooked into the exact same destination or IP address, that they could help with that for a fee... I have blink cameras,alexa, my wireless internet, ect. No gamers on my network...The router wifi would not even see the range extender due to that. The chat session person from Nighthawk asked for my number to get direct tech support involved. They called me from that interaction.
Did you set it up using wps first? If so, it sets up in default in a mesh configuration with the same ssid/password as the primary router you set it up with.
Your details are a bit vague on what you've done and whats exactly going on.
What router do you have?
What firmware is on the router and the extender?
What method of setup are you using?
What are the led's on the extender doing (all of them)?
How many devices are on your network?
Lets move on past the scam site/call you got. Not sure who you talked to but netgear doesn't sell you firewalls/security.
they do charge a fee for support but thats only if you're past your first 90 days of support period.
