selkins
May 05, 2020Follower
Netgear Model EX 2700
I need to change my security protocol. It prompted me to change it at one time, but I cannot figure out how to get back to it. I have a Netgear N300 Wifi Range extender Model EX2700.
May 06, 2020Guru - Experienced User
you can log into the device.<br><br>connect to it and go to mywifiext . net<br><br>the log in and change settings.<br><br>Or if mywifiext doesnt work, log into the router and find what ip address has been assigned to the extender. Use that to connect to it.<br><br><br><br>Or you can factory reset it. Then follow the installation wizard during the re-install and set it up with the settings you choose.
