selkins
May 05, 2020Follower
Netgear Model EX 2700
I need to change my security protocol. It prompted me to change it at one time, but I cannot figure out how to get back to it. I have a Netgear N300 Wifi Range extender Model EX2700.
May 06, 2020Guru - Experienced User
you can log into the device.
connect to it and go to mywifiext . net
the log in and change settings.
Or if mywifiext doesnt work, log into the router and find what ip address has been assigned to the extender. Use that to connect to it.
Or you can factory reset it. Then follow the installation wizard during the re-install and set it up with the settings you choose.
sorry about the first post being wonky. reposted.
