Befuddled2
Jul 09, 2012Follower
Netgear N150 as AP says 'no internet connection' msg
My N150 is running as an access point off my primary router. I've set it up with the usual needed AP type configurations (DHCP off, subnet set to same as primary, incoming line from primary router int...
Marto731
Jul 09, 2012Aspirant
To Mr Befuddled,
You are using the router in a position where an Access point is
suffient.
http://www.netgear.com/home/products/switches-and-access-points/access-points/default.aspx
So it may work for you, but it's not recommended.
The router will always be looking for a WAN input to connect to internet.
Marto,
Netgear
suffient.
Marto,
Netgear
