BenParkes
May 26, 2020Aspirant
Netgear n300 ex2700 wifi extender says password is incorrect
Hello Basically my router says "incorrect password" even though it is definitely correct. So I factory reset the router, reconnect to the router using the WPS button and it works again. Then afte...
May 26, 2020Guru - Experienced User
Suggestion 1? Factory reset the extender and re-run setup using the installation assistant and not using wps. wps gets coded different between different manufacturers.
BenParkes
May 27, 2020Aspirant
Hi, thanks for your suggestion. How do I set up using the installation assistant?
