BenParkes's avatar
BenParkes
Netgear n300 ex2700 wifi extender says password is incorrect
Hello   Basically my router says "incorrect password" even though it is definitely correct. So I factory reset the router, reconnect to the router using the WPS button and it works again. Then afte...
