sharathkumar11
Sep 03, 2016Follower
NETGEAR N300 WiFi Range Extender (WN3000RP) Antenna Broken, how to replace ?
Hi
i brought NETGEAR N300 WiFi Range Extender (WN3000RP) two years back, it was working good
it fallen down from certian height, after fallen down one of the antenna was broken
how can i replace / change the antenna ?
is it possbile to replace antenna, if yes please guide me
Thanks
Sharathkumar11
1 Reply
- DarrenMSr. NETGEAR Moderator
Hello shararthkumar11
I would check to see if the extender is still covered up warranty you can check by using the link below.
https://www.netgear.com/support/contact.aspx?cid=wmt_netgear_organic
DarrenM
