Eyedesigns
Jun 06, 2020Aspirant
Netgear Nighthawk AC1750 not working
The lights are on but these are flashing- internet, 2GHz, 5GHz. Can not connect to WiFi. Rebooted. Cable guy checked and internet is fine. Says router went out. Only had it 2 yrs
Eyedesigns
Jun 10, 2020Aspirant
Model is R6700v3. I restarted it. It rebooted but I don’t know how to reinstall it??
Jun 11, 2020Guru - Experienced User
You rebooted it but did you factory reset it? or just reboot it?
here's where you can get the install manual.
- EyedesignsJun 12, 2020AspirantYes. I held down the reset button for 15 seconds. It’s working. The white light are supposed to flash when working right? Not stay on all the time? The cable guy said he has the same router and lights are supposed to stay on. ??? He also said I need to replace it but it’s working.
- plemansJun 12, 2020Guru - Experienced User
Eyedesigns wrote:
Yes. I held down the reset button for 15 seconds. It’s working. The white light are supposed to flash when working right? Not stay on all the time? The cable guy said he has the same router and lights are supposed to stay on. ??? He also said I need to replace it but it’s working.there's many led's on these devices. go to netgear.com/support/ and type in your model. it'll take you to the support site with the manual that explains what they mean
