Jules_C
Sep 30, 2023Aspirant
NETGEAR NIGHTHAWK AC4000 (R8000P) ROUTER - WiFi Extender?
Can anyone recommend a WiFi extender for a NETGEAR NIGHTHAWK AC4000 (R8000P) ROUTER? Thank you
- Sep 30, 2023
Jules_C wrote:
Can anyone recommend a WiFi extender for a NETGEAR NIGHTHAWK AC4000 (R8000P) ROUTER?What do you need to do? Fill the odd gap, or create a large network?
Try plugging your needs into the filters on the product pages:
Isco
Oct 02, 2023Aspirant
NETGEAR Nighthawk X6S AC3000 Tri-Band WiFi Range Extender (EX8000): This extender is part of the Nighthawk series, designed to work seamlessly with other Nighthawk routers. It offers Inshot tri-band WiFi with dedicated backhaul, making it a powerful option for extending your network.
