DUP168
Jul 29, 2020Follower
NETGEAR Nighthawk Cable Modem WiFi Router Combo C7000
Recently upgrade the Netgear C7000 cable modem wifi router combo C7000 to XFI (XB7). Would like to know if I can you the old C7000 as a wifi access point? Please, provide detail instruction if can be ...
Jul 30, 2020Guru - Experienced User
There was a write up antinode did for the C6300. It should be pretty similar setup for the C7000.
Find it here: https://community.netgear.com/t5/Cable-Modems-Routers/Can-I-use-a-C6300-cable-modem-without-cable-internet/m-p/1463500
