ThatBloke
Mar 19, 2021Tutor
Netgear nighthawk connected to router...or is it ?
Model EX6410 ..had to type it here as its not listed in the above I've followed everything to the book and getting no joy in getting any connection Extender> Power outlet Waits for power ...
ThatBloke
Mar 19, 2021Tutor
What I am connected to is something called VM3687074. That is the name of my router .
Ive just unplugged the Extender and i had a brief disconnection then re-connected to the same Signal
Are you saying the extendere carries the same name ? If so how would you know what you are connected to? The Extender or the router itself ?
Mar 19, 2021Guru - Experienced User
to know which you're connected to, you'd either need to log into the router or the extender and they show you connected devices.
