Jamesi
Aug 11, 2020Tutor
Netgear Nighthawk disrupting wifi (not extending!)
Hi there, any help greatly appreciated. I set up the Nighthawk wifi mesh extender to extend the wifi in our house (via NBN in Australia). Rather than extend the wifi signal, the Nighthawk actually ap...
Aug 11, 2020Guru - Experienced User
What router is it connecting to?
What firmware is on the extender?
Did you set it up via wps or using the installation wizard?
Jamesi
Aug 11, 2020Tutor
Thanks very much for responding!
1. Router is a Telstra Smart Modem Gen 2 with voice Backup model LH1000
2. Firmware of Netgear extender - I don't know, how do I find this out?
3. I used the WPS facility on the modem rather than instalation wizard
- plemansAug 11, 2020Guru - Experienced User
Try factory resetting the extender and reinstalling it using the installation wizard. Reason I recommend this is WPS can get coded different between device makers.
- JamesiAug 12, 2020Tutor
Ok will do. Thanks very much. I'll let you know how I go. I thought that perhaps I had bought the wrong type of extender! See how I go
