asaroza's avatar
asaroza
Follower
Jun 29, 2020
Netgear Nighthawk X6 EX7700
Good Evening.
Fustrated for months ... not been able to connect this product to my WIFI the Netgear_Ext does comeup in the WIFI.  I have looked at videos, read how too and nothging.. I have delected the app and rebooted even got a netgear router nothing!
i need help and if you can video the how too's
Thank you
1 Reply
  • plemans's avatar
    In mesh mode, the extender uses the same ssid as the router. It doesn't use the _ext  if its running in mesh mode.
    What are the led's on the extender doing?
    It also has ethernet ports that you can log into it and check settings. Directly connect an device to the ethernet port (disable its wifi so it doesn't revert back to that) and you can log into it.
    That'll show you the status page of how its setup, or even let your re-run setup if you'd prefer.
    Or you can log into the router and check what IP address the extender is using from the attached devices page and use that to access it.
    https://www.netgear.com/support/product/ex7700
