RichG73
May 04, 2020Follower
NETGEAR Nighthawk X6 R8000 WiFi Cable & Fibre Router - AC 3200, Tri-band
Does anyone know if this model is compatible with Sky Q modem?
1 Reply
Pretty much all routers are compatible with a simple modem.
Sky q isn't a simple modem. most often they sell modem/router combo devices.
https://kb.netgear.com/30186/What-is-Double-NAT
That can end up the issue when you go that route. Then you either have to put the sky q device in modem only/passthrough mode or you have to put the netgear in access point mode.
