Khaled0000
May 03, 2023Guide
Netgear Nighthawk X6 Tri-Band WiFi Mesh Extender AC2200 - Lights flashing (HELP)
Hello, I have this NETGEAR Nighthawk X6 Tri-Band WiFi Mesh Extender AC2200 that has flashing lights but no functionality after power was lost to it during a software upgrade. I assume there is no...
May 10, 2023Guru - Experienced User
If its assigning an ip address, it should be working.
Are you able to access it while you're pc is connected to the router and the extender connected to the router?
Khaled0000
May 11, 2023Guide
Hi,
No, i'm unable to connect to the extender whilst my pc and extender are connected to it. The extender was operating normally for a few seconds before going back into it's previous state today for some reason.
